- Sep 10, 2024
- 35
- Plaster
- Pentair Intellichlor IC-20
Hi,
I got a box of Taylor K-2006C test kit from pool builder (for my new pool). When I start to use it to test FC and CC (FAS-DPD), I got confused with the instructions.
The instruction says, if 1 drop = 0.2 ppm, I should use 25mL sample, and if 1 drop = 0.5 ppm, I should use 10mL sample. I assume it refers to the R-0871 reagent.
But there is no where says if my R-0871 reagent is 1 drop = 0.2 ppm or 0.5 ppm. (The R-0871 bottle is 2oz size), even the test kit box lable just says 1 drop = 0.2 or 0.5 ppm.
How do I know if my reagent is 1 drop = 0.2 ppm or 0.5 ppm, so I could choose the correct sample size (10mL or 25mL)?
Thanks!
Thanks!
