Hello,
I am in the process of closing - water has been blown out of jets, falls, equipment.. I still have an annoying issue with water in the skimmer well. It comes up from what I believe is the drain hole. The hole that sucks water (skims) refills after I blow it out from water that comes up from the drain hole (see pic). The hole that I have circled in the pic is where water comes up from. It refills the well to about the 3" mark without fail every time I blow out the skimmer line (I'm doing this from the pump area). Is it okay to have some water down there (we get well below zero and freeze throughout the winter). If I dump plumber anti-freeze and use a sacrificial lamb will this ensure that I won't have freeze damage? Or do I need to get that water out? In past years (where I've had help or had a company close it) I am sure the well was dry. Thoughts? Thanks.
