If you are talking about DE returning to the pool as it is being added, yes. If the valve shaft O rings are worn/missing this will happen. Which valve is it? If an older Pentair with the stainless-steel shaft, the "pucks" holding the O rings are held in place by small "e" clips that break/corrode/disappear. The "puck" moves and the same thing will happen.
