Hey guys, home owner/not a professional, have a question.
I installed a new Nidec Neptune 2.7 variable speed motor earlier this week. I was reading through the user manual for setup and one warning it mentioned was to avoid getting the motor and control panel wet. Well with my luck, woke up to it raining fairly heavily this morning (first real steady rain in over 100 days here).
My question is, when they say keep it away from water, do they mean sitting in water? Or will rain water hitting the outside of the motor really cause damage? I was going to be adding a solid roof to my pump area instead of the shade structure that's currently there, but wasn't planning on it raining so soon. I also can't think of a way to always keep it dry without fully enclosing the motor, but in Arizona, the temps inside an enclosed area would cook the motor regardless.
This is the first variable speed motor I've had, I don't want to mess the new motor up, but should I be concerned about it getting wet via rain? It's not sitting in water, the motor is on a stand to keep it elevated and the area is gravel with great drainage and has never pooled water anywhere near the pump.
