Hello Folks,
I am researching mechanical methods of pool chlorination and would like to hear from the experienced folks online.
Briefly: New to us pool, which is actually 22 years old but in excellent operating condition. I am a pool rookie but learning fast. Currently we have a weekly pool service but I hope to soon take over all maintenance full time.
I just recently became 'educated' about chlorination after the old out-of-service Rainbow Lifeguard 300 chlorinator developed a leak (the hoses disintegrated) and I was forced to bypass it completely in order to fix the leak. It hadn't been used in years so it doesn't affect the status quo, but it brought it to my attention.
Our pool service puts chlorine pucks in the skimmer whenever necessary; my research indicates that the pool pros are about split 50-50; some say it's a horrible thing to do and some say it's OK.
I'd just as soon use a mechanical system, like the Rainbow Lifeguard 300 already installed on our pool, but I have been told that they can cause serious damage to my pool heater, if they are plumbed incorrectly. On my setup, the intake is plumbed after the pump check valve but before the DE filter, and the output is connected to the spa bypass pipe after the check valve (and downstream from the heater).
Is the erosion feeder method OK if plumbed correctly?
I am also aware of the salt water chlorinator option but haven't researched them enough to form an educated opinion - can they be easily retrofitted to a system like mine?
Are there other factors I should consider before making a decision?
Thoughts? Ideas? Opinions?
Thanks!
Thanks!
