I am closing my pool. The pool store has in the past. I have all the slamming, decreased water levels, etc. all finished. Just want to make sure my lines are blown out properly. I have an inground with 1 skimmer, 2 returns and main drain. I have the cut off valve to main drain, etc at the pump. I plan on using a 5 HP Shop Vac. Should I blow out from skimmer? Do I need to close any valves, etc? any advice is welcome. Thank you
