Laurie, having looked up a number of your old posts, I've discovered that you have an AG pool - therefore liner. (Please give a look at the sticky I authored in the "POOL SCHOOL" section and think about setting up a signature with your pool's specs
Your original question was about the high pH when closing, I followed how and why the original shifted focus and have enjoyed following this thread. I do want to give
my take on a higher pH for closing a liner pool. In the end, it depends on whether rain and snow will end up mixing with the pool water [this depends on whether your cover allows water through or if you even use a cover] - if the precipitation will mix with the pool water, I believe you will be better off closing with a high pH. The reasoning behind this is that at the very least the precip. is 7.0 and will dilute the pH of the water, if you live where the precip. is acidic it will draw the pH down even faster - liner pools should be kept with a minimum of 7.0, I shudder to think of the damage that could be done to a liner that sits unchecked for months with a low pH- a lot of unnecessary wear on the liner can be prevented by anticipating the effect of neutral/ acid precip. and having the pH on the higher side when closing.
I know that in the second post on this thread, Dave said to leave the pH at regular, Summer, levels and that he doesn't cover his pool - all I can say is that Dave has admitted to 'not being too smart' in the past -- in fact I'm positive he never
bought one of Duraligh's great kits
, HE probably uses test strips
(most likely expired ones :lol: ) {sorry Dave, you know I'm just "
" -ing fun}
As is typical, I forgot about 1 thing while
trying to be funny :grrrr: What you
MAY have going on is what I've termed "Matt's Mud" or "4X4 Algae". Matt4x4 posted about it on PF last summer. This seems to be a form of persistent algae that has the look of some of what you describe. I'll either pm him or x-link the threads from there - but it won't be tonight I've gotta go
