Is there such a thing as a portable pool heater that could run off, say, a bbq propane tank and 110v for a self-contained water pump? If even only designed for smaller pools?
More curiosity than anything. If something like that existed, were cheap enough and practical to raise my pool even a few degrees, I'd be interested. Without any efficiency loss, it sounds like a 20lb propane tank would heat 15,000 gallons about 3.5 degrees. I'd assume there's a fair amount of efficiency lost in the heating process making it impractical for most pools aside from smaller above ground pools.
