Hi,
I drained my pool, after that some of the popup heads didn't pop up, so I researched and found suggestions about popup control module. I inspected it and some of the valves were bad. I bought another, similar module control online. The new unit looks almost the same as mine, but it has no label, valves firmly sit, and the new gears look a bit differently than mine. I tried it anyway and still some of the popups don't pop up. The same heads pop up all the time. There are 13 heads and only 5 pop up. Notice these 5 pop up all at once. It seems the gears don't change and only some of the ports are open. I can force all 13 heads up by turning off the wall returns or removing the control module. Water pressure looks good. There is a small leak at the air bleeder valve on top of the filter. No other leaks. I also made sure I set the control module to "run" mode by setting the switch on top of the dome.
Does anyone have a suggestion on how to troubleshoot this? Is it really the control module? What should be the correct gears configuration? Can I swap out the gears (Actually I did try, but the old central spindle didn't fit the new shalf. I could make it wider but haven't done that without asking)?
I am attaching some photos hers for references. Thanks for helping!!!
