Jandy equipment. It's about 6 feet above my pool/spa because of lot elevation. Pic attached.
Problem is, while in normal pool mode it won't fill the spa. It will if I put the control board to "spa fill". Spa attached to pool and spills in.
So, I thought maybe it was one of the 2 check valves. Replaced one, nothing new. Took old one, put it in the other spot and still nothing.
Cleaned the filter really good. No change.
Opened the pump and sprayed the hose into the impeller to try and loosen anything that might be caught but no change.
Lid seems to be fine, not bent. Rubber ring lubricated and intact.
Is it one of the 3 fill valves leading to the pump? They seem to be fine. Thinking I will replace the O rings on each of them.
Is there air slipping somewhere causing the pump to lose suction and not have enough volume/pressure to fill the spa? But if so, why does it work when in "spa fill" mode?
Is it the impeller? Was replaced maybe 5 years ago? Original outer pump housing but should that matter?
Anyone have any suggestions? I am losing my mind here. and thank you for your help.
Great weather in Texas allows me to work on the equipment unlike last week when everything was frozen and I was sweating balls trying to keep up.
