Hey guys,
I bought a house with an above ground pool so I’ve been trying to learn everything I can, but I’m having a tough time. I’m fine on chemicals, my water is nice and clear, but these are my issues:
1. Where the hoses connect to the pump and filter, they keep dripping. I’ve tried a few different things. They are clamped down tight. Any advice to stop the hoses from leaking at the connections?
2. Some water comes out of the clear pump lid no matter how tight I get it. I’ve bought a new o ring, any other advice?
3. The pump only fills about half way with water. I’m guessing it’s due to 1 and 2 above. So many air bubbles come through to the pool.
4. No matter how much I vacuum, dirt or sand settles on the bottom of the pool everyday. I’m assuming it’s sand, but I’m not sure. Do I just need to replace the sand?
5. When I try prime the pump, I remove the lid and the pool water just starts overflowing like crazy. I can’t take a hose and fill it up because it’s pouring out so fast.
My filter only has winter, rinse, backwash, and filter. No way to recirculate.
I can just buy a new pump and filter if that’s the easiest solution.
