- Jul 6, 2022
- 26
- Vinyl
- Hayward Aqua Rite (T-15)
Hi all, just wanted to ask a few questions while gearing up for the coming season. This is our 3rd year with this pool (came with current house). I’m still new to this and don’t know what I don’t know, so some of these questions may be kind of obvious.
- Testing when opening last summer showed almost no salt or CYA in the water (had stable chemistry at the end of last season), which didn’t make sense as I thought those chemicals should stay around and only dilution from discharge to waste/refilling would really change those values. I had to add over 300 lbs of salt. Are there any possible reasons for this or is that within a normal range?
- I've had a hard time maintaining pH, it seems to want to settle around 7.8 by itself but sometimes goes higher. I’ve seen various comments on what is acceptable. I was wondering if that was OK for a salt pool with a nearly always running pump, it didn’t seem to cause any issues with swimming.
- Are you supposed to seal cracks in the surrounding pool deck? We got a new liner in 2023 and quickly several mini canyons started forming underneath. I know liners with sand bottoms are never real smooth, but these are so bad that people have tripped and it is almost impossible to get a vacuum or brush into many of them. The only thing I can figure is that ground water/runoff is getting under the liner and channeling out the sand. This pool's 30+ years old so there are many cracks in the concrete deck, many are unsealed, maybe water is getting in those cracks and running under the pool?
- I have also learned that our sand filter may also be undersized, the installed S200 doesn’t seem like the recommended unit for ~28k gallons. Plus, our pool seems to consistently have a pretty high filtration demand due to all the dust and tree junk that falls in there. I am going to change the sand (suspect the prev. owner didn’t use proper pool sand & I have to replace the O-ring anyway), and didn’t know if I should use something other than the normal filter sand that might do a better job considering the demand. The reason I ask is that I have seen some sand alternatives say you can use less by weight, but not sure that means I'd be able to add more (not sure if it would cause flow issues, etc.)
