Pool Math iOS app trouble setting SWG for 2019 Hotsprings Flair
lagreca
12
Idaho
I'm trying to setup the Pool Math iOS app. When I tell it I'm using a SWG (salt water generator), I can't find mine listed (2019 Hotsprings Flair hot tub). I tried to figure out how many lbs of chlorine output my tub has, and it appears to be .02-.03. However, I can NOT add the number into the calculator. Am I doing something wrong, or is the salt water portion of the calculator not for hot tubs?
Huh. Before I responded, I checked it in "Effects of adding" and it worked. You can certainly use Effects of Adding.
I did not check if SETUP would accept ".02" and it does not.
Let's see what @Leebo says...
Reactions: lagreca
