pool leaking near inlet and outlet
UnderG
In The Industry
May 21, 2024
1
Bridgewater
my pool is leaking near inlet and outlet valves/pipes.
I have 32mm hose clips around them but water is still escaping.
In my previous pool - one with metal frame pool i was supplied with these little 10cm long end caps with holes in which went into the inlet/outlet valves from the inside of the pool and that made the inlet/outlet valve pipes more rigid and I could then clip the hose clips on rather tightly. sorry I don't know what they are called. If I did I could search for them.
but does anybody know what I am referring to and where i can buy something like this to fix this issue?
my pool is only a 10ft / 3m diameter bestway pool (with inflatable top ring)
Welcome to TFP.
Post pics of your pool and the inlet/outlet pipes and clips that are leaking.
Reactions: wireform
