Hi long time listener, first time caller here. I have a 10 year old, 20,000 gallon inground pool, vinyl liner. Winterized it myself last couple of years, with this year's winterization completed about Sept 1. Since then I've lost a steady amount of water, probably about 12,000 gallons. I look carefully for a hole in the liner but no dice. Decided about a week ago to pump out the rest of the water (too cold to dive in) and plug the two main drains with rubber expansion plugs. Yesterday I completed pumping about 8,000 gallons of water back into the courtesy of the local high water table and sump pit in my basement. My local pool store expert suggests that it could be a leak in the main drain piping, or the gaskets at the main drain. If the water level recedes, its a failed gasket. If the water level maintains, then its a leak in the main drain.
I plan on monitoring the water level closely over the next few days. Wife is urging me to call a pool leak repair professional but I'm too cheap. Is there anything else I should be doing in terms of troubleshooting?
