I have a Pentair Matertemp heater. The problem is the heater is sensing a higher temp than the actual water temp is. I have replaced the thermister 2 times and still have the same issue. When I try to heat my hot tub I can only get the heat up to about 98 because the heater thinks it is 104 and will not heat anymore. The remote says it's only 98, and I have checked the temp of the water with a laser temp and it is only 98. So I can't heat the hot tub to around 100 or 101 like I prefer. Any insight into this will be greatly appreciated.
