I can assure you that your pump is not using significantly more power than it used to.Bottom line is I get charged by kWh, and that's what's of interest to me.
If the energy use is higher, it is due to running longer.
If you want to lower the energy bill, get a variable speed pump.the 2HP Century B130 pump uses about 2,400 watts
HIs timer is set to run the filter pump 4 hours a day in non-freezing conditions.If you want to lower the energy bill, get a variable speed pump.
How about if you use a pen or crayon or maybe a piece of chalk?I doubt a VS pump pencils out until the SS pump dies.
I use a twig in the sand. Easier to fix all my errors or start over.How about if you use a pen or crayon or maybe a piece of chalk?
That makes zero difference.I'm assuming the initial higher values correspond to higher energy due to the system first starting up.
What is the pressure when the pump is off?I suspect the high DE filter pressure may have something to do with that as well (32 psi after complete clean).
It's a bad gauge.When the pump is off it's about 10 PSI.
The power company just guesses about what is on and they do not know for sure.
What else could have come on for a short time that uses about 1,600 watts, 2400 watts or 4,800 watts?
Something using about 1,600 watts turned on for about 1 hour and then something using 2,400 watts turned on for 30 minutes.
The pressure should go to 0 when the pump is off.I have a way to depressurize the system to check if it goes down to 0, but don't want to get any air into it for no reason now.
