Polaris PB4-60 booster pump leaking
dcp063
57
Atlanta
Hayward Aqua Rite (T-15)
My booster pump is leaking. Seems to be where two sections meet. I’m learning most solutions to pool plumbing leaks are replace a seal of some kind. Is that what’s going on here and is it DIY?
Thanks
Looks like the shaft seal is shot.
Look for "Polaris PB4-60 rebuild kit" or "Polaris PB4-60 Go kit"
Make sure it includes the shaft seal.
Thanks
View attachment 629332View attachment 629331
Any/every time one sees that corrosion on the un-painted portion of that type motor it is the shaft seal, a PS-1000. Get it repaired soon or you will be looking at replacing the motor. They are expensive, as motors go.
If that pump ran dry for any length of time the impeller will likely need replacing as well. That's the usual cause of a seal going bad in a PB4-60.
Thanks. Do I need to completely disconnect and rewire or can I leave it in place and kill the power at the breaker?
It is still pushing water through so hasn’t run dry as far as I know. The cleaning robot is a bit sluggish recently though
The breaker is fine as long as it is just for the booster. Many times a booster pump is on the same circuit as the main pump and tripping that breaker will stop the pool from circulating. Check to be sure.
Check the wall/in-line screen if the Polaris has been running slow. It could be clogged.
Got it. Thanks
I just cleaned the line filter, replaced the pressure valve, and replaced the swivel connection. Also cut back some of the hose and replaced all of the other connections. Didn’t see anything overly worn inside of the Quattro body; gears looked good, nothing broken. Still didn’t want to climb walls like it used to
