We are in the Northeast. We just poured concrete slab for Endless Pool. We made the slab a bit bigger to accomodate a separate hottub. I have "free electricity" from my solar panels (I generate more than I use), so I've been looking at Arctic Heatpumps - they are a bit pricy, so I'm trying to see if it is possible to design the plumbing so it can service both bodies. This would simplify managing the water chemistry which is another big motivation.
The pool and hottub are separate (no spillway). Most dual zone setups I've seen are designed with spillways in mind. So is there any reason I can just directly connect the 2 bodies with an appropriately sized pipe with a valve? See diagram 1.
When normally, the system would filter and heat both bodies at 80 degrees, and the water would flow as noted in green lines in diagram 2. When we want to use the hot-tub, water would flow as shown in brown lines in diagram 3.
First time owner, so any critique / suggestions welcome! Thank you so much.
