Hi there! My pool has gone through it over the past 2 weeks from extremely high winds and city fires. I was evacuated for a bit and turned my filter off before I left. After coming back (thankfully I was not too close to the fires), I found that my filter is no longer working and the pool has a layer of soot and debris. I am assuming the filter needs to be cleaned. Looking for some advice as to next steps. My plan below:
Do you think the filter will need to be cleaned multiple times?
Do I need to SLAM instead? [Edit: I don't see any visible algae, but guess I will need to wait until testing chems to see what levels look like]
Should I just call in a professional for one-time help?
I will continue browsing thru the TFP and Swim Univ. resources, but thought asking here might be easier and quicker. THANK YOU IN ADVANCE!
Today I skimmed - brushed - skimmed - brushed - skimmed the pool (in that order) and got it as clean as possible (see photo). My plan is to order DE pool filter cleaner today so that I can clean the filter ASAP. After cleaning the filter, I will run the filter and manually vacuum the pool. I will run the filter for a while (in addition to skimming and brushing and vacuuming) until water looks clear. Will also test using my new TF Pro kit and adjust chems after running the filter.
