Well I'm having to add acid every 2-3 days. Just going to be FOREVER fighting!
Try to harvest as much rainwater as possible. I try to minimize my fill water (TA 330) usage. During the winter and spring we typically get enough rainfall that I don't need to use fill water. In a summer drought, I'm adding MA twice a week.
Reactions: Tattooed Nurse
We very rarely get rain here in West Texas. It would be nice but we just don't.
That’s very excessive evaporation. Are you leaking out of the overflow by chance and having lots of autofill water making up for it?
No obvious leaks that I am aware of. Our pool is on a concrete slab so you would think I would see it. It is just very dry, hot and windy here
I think aeration is appropriate for those situations where a rapid TA reduction is necessary, such as very high CSI in a plaster pool after a refill. However, for long term maintenance of pools in arid to semi-arid climates, such as mine, I found that TA rises very rapidly requiring this procedure to be repeated fairly often which was not very appealing to me and why I chose to install an acid dosing system. I find It is just a lot less work.
Reading your comment for the first time. Can you elaborate on the acid dosing system please as I am having to add acid CONSTANTLY to keep my pH and TA within range.
No obvious leaks that I am aware of. Our pool is on a concrete slab so you would think I would see it. It is just very dry, hot and windy hI
I get the feeling that 1” per day is excessive even in the desert. Maybe someone else can comment on that. I might try and do a bucket test to see if it’s actually 1” as well as turning off the auto-fill for a few days and see what happens.
Haven't done the bucket method but have turned off the fill water for a few days just to see how much we are losing per day. Only made it 3 days and the level got so low in the skimmer that we were sucking air and got an air lock. Luckily we were keeping an eye on it and it didn't run our pump dry and burn it up.
I’m betting on there being a leak…
Reactions: PoolStored
