- Jun 7, 2017
- 9,958
- Plaster
- Jandy Aquapure 1400
I am tired of guessing what my pH is. I look and look....and look....and look some more at the tf100 pH window and just can't tell what color it is. I thought it was around 7.8 the other day so added just a touch of Muriatic to get it a few points lower. I took a sample and tested it with an electronic pH meter that I use for my aquarium and it tested at right at 7. I then used other drop tests (different kits) to test and each showed a different result (all closer to 7). I really just want an accurate test! Can anyone recommend an accurate test? I think at this point I would prefer an electronic meter. Of course there are hundreds to choose from. HELP!!!
