I recently acquired a new home and with it came an above ground pool. I'm fairly decent with pool knowledge and used this forum in the past.
Pool Specs: 18' x 34' Above Ground Oval with deep end
Estimated Gallons: 24,500
Currently running single speed 1.5hp with a small sand filter
Looking at going to:
Pentair Intelliflo Variable Speed Pump: XF series for larger flow rates or high performance less flow pump
Havent picked a new sand filter yet but going to spec a larger filter for more filter area.
I searched these forums looking for information regarding the variable speed on an above ground but couldnt find anything. All help is greatly appreciated. What model pump would one use for the pool I have?
I appreciate the help!!
Thanks
Thanks
