- Oct 31, 2021
- 35
- Plaster
- Jandy Aquapure 1400
Hi Pool professionals,
I have a Pentair Prowler 920 cleaner stopped working and I am trying to figure out which part is malfunction. Below are some observations
Thank you very much,
Joshua
- Yesterday, the robot cleaner stopped working about 1 minutes after I turned it on and I was not able never turn it on after.
- The light on the Power Supply looks normal and the weekly program button is also functional.
- After turned on the power, the blue LED on the cleaner does not lit at all. The robot does not moving and the impeller does not start either
- I have reconnect the connector between the power supply and the robot many times
- After the power supply is switched on for 30 seconds, I measured the DC voltage out between two output poles which shows 29.1~29.2 V, however when the Power Supply is switched off( with the110V plugged in) , it reads ~28.5-28.7V
Joshua
