Agree, but there's also the possibility that the measurement of the temperature is inaccurate. I'm trying to rule that out before tearing anything else apart. If it's a temp error problem, I think it's most likely in the wiring, not in the three sensors I've tried. I have twisted together a 2.2 MEG OHM and a 1.5 MEG OHM resistor to make 3.7. How do I physically attach them to the SFS wire terminals that lead back to the circuit board? It's hard to get a connection. Also, does it make sense that the heater will fire when NO sensor is attached to the SFS wires? Does it tell me something that it will?
