- Dec 26, 2019
- 1,848
- Plaster
- Pentair Intellichlor IC-40
Ok - I've been reading up on the IC40 salt cell on here for the past couple of days. I've noted 2 major things... The flow switch can have issues and the salt level readings can be off based on cooler water temps. New pool, plastered and filled at the end of January (thread here - New Pool in Broken Arrow OK) Just added salt last Wednesday. PB didn't quite get enough salt in, so I finished adding over the weekend, to bring it up to 3400ppm (Taylor test result). IC40 manual says 3600. At one point, on Monday, my cell was reading 3250ppm. I think the water temps were above 60 that day. That night the water temps went back down to around 57. The cell was reading 2650ppm Tuesday morning.
So I think the sweet spot for temperature on my cell is 60F, to provide a somewhat accurate salt reading. At least that is what I am noticing. This leads me to my main question. The red LED for low salt. The manual states this:
Red LED: Low salt. The water salt level is below 2800 ppm. The
IntelliChlor SCG will be producing chlorine at reduced efficiency. It is
highly recommended to add salt. See (*) Note below.
Red LED: Very low salt. The water salt level has fallen below 2600
ppm. The IntelliChlor SCG will not produce chlorine until salt is
added. The IntelliChlor SCG is OFF. See (*) Note below.
It does not indicate any method of differentiating between the "low" and "very low" points, such as flashing or whatnot. So essentially, if you are looking at the cell, and the red light is on, should I assume that it is incapable of generating?
The other question I have is regarding the addition of salt to the pool. The instructions in the IC40 manual state the following:
5. After 24 hours, verify correct salt level reading by checking the LED indicators on the IntelliChlor
SCG and by a separate reliable test method.
6. Power on the IntelliChlor® SCG and set the Sanitizer Output level to the proper setting to maintain
the appropriate free chlorine levels in the pool water (i.e., within the 2.0 - 4.0 ppm, APSP
recommended range).
When it states "power on" in step 6, I am assuming this is meaning that the unit is set to generate 0% while adding salt, since in step 5 it recommends looking at the LED's to verify the salt levels. What are the implications, if any, to having the salt cell producing chlorine during salt addition?
For those running the IC40 - what do you target for your salt range?
--Jeff
recommended range).
--Jeff
