Pentair GloBrite to Jandy LED Nicheless Light Conversion Questions
schwichb
2
Palmyra, WI
Fiberglass
Good Day,
I've been a long-time user of these forums primarily for help with chemistry questions for my 16x40 fiberglass inground pool (Imagine Pools, "Illusion" model) and greatly appreciate all the help I've received. I recently tried to replace a burned-out Pentair GloBrite LED bulb (P/N: 602055) with a Jandy LED Nicheless bulb (P/N: JLU4C12W100P) as I've read from several sites that it's a compatible replacement (and is hopefully much more reliable). However, I've run into a problem with securing the new bulb in the niche. The Pentair bulb has a "camlock" mechanism (in light gray in the picture) at the back for the bulb and a white face-seal gasket. The Jandy has "normal" threads at the front of the bulb and the niche has no way to "engage" these threads. While I can get the Janey bulb to sit flush in the Niche, I can't see a way to secure it. So, I have some questions:
* Is there an adapter kit available and, if so, could someone let me know the appropriate part number?
* Is it "okay" to just pull the bulb flush, essentially securing it with the wire at the junction box back by the controller (this seems like a bad idea to me)?
* Should I install the white gasket from the Pentair bulb onto to Jandy bulb (although I don't know how to get it tight against the back of the Niche)?
* Is it okay to just let water leak into the PVC conduit run (this also seems like a bad idea)?
* Is it possible (or recommended) to replace the niche in the pool (also seems problematic)?
* Did I just learn a $400 lesson on not doing enough research before buying the Jandy bulb? :)
I'm open to other ideas and suggestions as well. Thank you for any help anyone can provide and thank you again for being such a great resource for pool owners!
Bryan
SE Wisconsin Pool Owner
Welcome to TFP.
Get the Pentair Microbrite adapter P/N 618040 that adapts your niche to a screw in nicheless light.
