pebble tec and raw feet
Feb 20, 2018
23
Wyomissing Pa
Hello,
We just got our new pool installed, it has pebble tec. My feet are getting torn up!!! Like someone took a cheese grater to the bottoms. This is only happening to me, the rest of the family is fine.
What gives? Will I toughen up? Has anyone else experienced this issue?
Others on the forum with pebble tec have reported that issue. Use the search box in the upper right of the page.
Not much you can do about it once it is in -------
m,
Not sure why just you, but pebble finishes should be graded like they do sandpaper... 30 grit or 60 grit, etc...
I always try and tell new buyers to find a pool and walk in it before buying.. It is normally nothing like the tiny sample they show you.
Thanks for posting,
Yes, unfortunately. And I went to my contractor's pool showroom ahead of time to avoid this very issue. I waded around and felt the various surfaces with my hands and feet. Settled on the finest pebble. Seemed OK. But when it got installed I was disappointed (I was replacing plaster, so I was spoiled). I've grown a bit more accustomed to it. My feet are OK, but it's not comfortable to sit on, a natural, and mine would definitely take skin off elbows and knees is scraped just so (any areas that are not as tough as feet and hands). I didn't think to feel the showroom surfaces with my elbows!
I suppose winter feet (before you start walking around barefoot in the summer), would exacerbate the issue. You won't likely toughen up in just the pool. You'll need to walk around barefoot more, or something. Worse still, someone here warned me that pool surfaces tend to get rougher over time, they don't get smoother. So there's that. Learn how to manage your water with what they teach here, and your surface will likely stay smoother longer for it.
Worst case, depending on the actual product you used, you might be able to have it polished, which would smooth it out directly proportionally to the amount of money you want to spend having it done.
On the bright side, it'll last a lot longer and look better longer than plaster would. Does that help?
All pebbles are not created equal, really depends on the installer. They did a real good job of sanding my pebble sheen down to be relatively smooth, used a big sanding tool like a floor buffer or weed whacker with a sanding attachment. Not so with our friends' pebble tec, which is so rough that our kids (and sometimes we ...) always leave with various cuts and scrapes on our feet and other body parts. First couple of times I swam in their pool I thought that we just weren't used to the pebble surface, but now I know it was a bad install job.
Totally agree. I watched my installers buff my pebble. They used the "weed whacker" gizmo. I can feel, on the nose of the steps for example, where some is smooth but sharper ridges, too, where they just didn't spend the time to smooth it all out evenly. And that's the rub when it comes to viewing and feeling "sample" pool surfaces. A lot about how your pool is going to turn out depends on the "crew'o'the'day" that shows up to do the work... Very hard for the consumer to predict or control any of that.
After 6 months of our backyard remodel (we began the project on 2/11/19), we were able to enjoy our pool! Our contractor told us we had a Pebble finish (no mention of Pebble Tec) come to find out it was like walking on chards of glass!!! We had no samples to check and thought it would be a smooth surface to walk on. We are extremely disappointed and expect our contractor to fix this issue.
