While we often point to water clarity as a key indicator, I would tend to agree that in your situation it's all about time & filtration now. We know sand can be a bit slow. If you don't see improvement soon, perhaps a little DE added to the sand?think it’s ok to start letting levels drop while pool continues to clear?
I did add some Cellulose Fiber to the skimmer this morning- no change in pressure but clarity is betterWhile we often point to water clarity as a key indicator, I would tend to agree that in your situation it's all about time & filtration now. We know sand can be a bit slow. If you don't see improvement soon, perhaps a little DE added to the sand?
Add DE to a Sand Filter
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.www.troublefreepool.com
Yeah, i guess it wont hurt, Ive been at 24 Slam level for 2 days - still have 7 gallons left so why not?Maintaining SLAM when the FC holds is waaaaaaaay easier than starting a new one.
OCLTs with cloudy water are just for funsies and don't count. Without the clear water, it's a fail on the three exit criteria. There is no need to fail more than one. SLAM on.
While I agree it's likely a mechanical only issue at this point instead of a chemistry issue, algae grows a biofolm to protect itself from harsh environments. The next brushing may expose new layers needing to be killed, while the water itself is algae free.
You're in the homestretch, finish it proper.
You got this.
Yep- sameWell done. I find that the hardest part on my patience is the after the SLAM waiting for the filter to do its job!
