I acquired a paramount in floor system that has 6 modules. 4 of the modules are 6 ports and 2 of the modules are 2 ports. It has a challenger booster pump and a 2.5 HP connected.
All the module gears need to be replaced, and I can see the 6 ports are about $70/each. The 2 port are about $158/each. Looking at the old gear modules, the only difference between the 2 and 6 ports is that the 2 gear modules have a clip that connects 3 ports together on each side.
My question is, can I get a 6 port gear and put the clips/tube on top, essentially converting a 6 port into a 2 port gear module?
