Hi - this all started with me "thinking" that my pool is slightly cloudy. But this could also be me trying to be too perfect and precise when it comes to the pool. I test almost daily (or every 2 days). I dont always log the results in the PoolMath app. But in most cases, my FC is in the 5ppm, PH (7.5-7.8), Alk is steady between 80-90 and Hardness never moves from 130. CYA is 60 and has been steady. I run my pump for 24 hrs (1800rpm) and sometimes would run for 2 hrs at (2400rpm). The total movement in water does cover more than 3 times the total water capacity of the pool.
So again, I feel like the pool is slightly cloudy, although others feel it looks fine. I know want to use a pool clarifier since there may be a reason for the cloudiness. I have done 2 things...
I ran my pump for a good 6 hours on high (2900rpm) and seems to be more clear than prior. I also did an Overnight Chlorine test...and low and behold, I lost 1.4PPM overnight (12 hours).
I guess I have 2 questions...
Is this just due to poor circulation and I need to run my pump on higher RPMS more than just running long with low RPM?
Or do I need to shock (assuming algae problem) since the overnight chlorine loss test showed I lost 1.4 ppm
I used a taylor kit and tested with 25ml, so I can measure with 0.2ppm per drop.
