I just took over a new build for a company that was in desperate need of help.
They went wayyy overkill with their design.
I will attach pictures.
5 VS Pumps, 2 Heaters, 2 Filters, all stacked on top of each other and shoved in a corner with no room to work. Pool/Spa combo but they plumbed everything individually so it’s 2 bodies of water.
I need to get this all wired up to the OmniLogic board. I work with Omni frequently but it’s usually a simple set up 1 pump 1 heater. I have the comm. cables set on the pump ends, but need help with the board end.
How do I wire 5 pumps and 2 heaters to the comm. ports, or should I be using the relays?
The builder/electrician has nothing on the relays, everything is hot to breakers.
Please any help will be greatly appreciated.
