My house was built in 1985. There is a back flow valve but if I close it off, it doesn't appear to shut off the autofill lines. Should I care?
I am trying to sort out the plumbing. We have a very minor leak and the autofill Iines were pressure tested and didn't find anything. Now I just want to be sure the back flow would cover the pool. Why would it be there for any other reason?
Images - three images of water line into house.
Fourth image are the the autofill lines. There are two turn off valves. One on the right turns off both pool and spa autofill. One on the left is a mystery and I don't know what that line goes too. If you look at the first picture right before the hose line there is a line that goes underground. I am not sure where this goes either.
Any thoughts or insights to this puzzle are welcomed. Thanks in advance.
