@Mdragger88 - I had granulated chlorine, chlorine pucks, and non chlorine shock.
Ok it's empty. Weather could be better. It's raining, but not too cold.
Here's my progress:
Over filling, running the equipment after adding 150ml of liquid chlorine 12%.
Added Ahh-some, running the equipment with the aerators on.
Got a bit of grime. Not much foam.
Added the correct amount of Ahh-Some because I added 4 level HALF teaspoons the first time. Got more grime. I sprayed, wiped, scooped, scrubbed.
Draining, spraying, wiping, scrubbing.
Ran the jets when empty. Shopvacced, sucked all the crevices, and jets.
Refilling.
When should I add chlorine? Which one? I have granulated chlorine. If I've grokked anything from Nitro's phd thesis and you guys I need to add CYA. I don't have a way to measure it, my K-2006 kit hasn't arrived. Should I assume adding 40gms of granulated chlorine for 36ppm of CYA? When should I add it? If I'm wrong about all of this what is my next step?
Here's my progress:
Refilling.
