- Jun 20, 2024
- 54
- Vinyl
- Solaxx (Saltron) Reliant / Purechlor R5
A few more questions since you were so helpful last time!!There you go!!!
You have, I think, 8 levels of output
0 = 0 output
1 = 12.5%
2 = 25%
3 = 37.5%
4 = 50%
5 = 62.5%
6 = 75%
7 = 87.5%
8 = 100%
So on "4" for 24 hours, you make 5FC or so (1.15 is the number they give, might be more might be less).
Current readings from this morning....
FC-12
TC-12
CC-0
PH-7.5
CH-325
TA-100
CYA-60
I have turned off the SWG to get the chlorine back to a normal range. I have found that I have been having yo test the chlorine 2-3 time because it's never the same reading each time. I kind of figure the average. Is that normal??
Also, I believe we have mustard algae. Ugh. If we did, why wouldn't the CC be off??
I took water to get tested at a pool store because I have been curious how off their testing is. This was their results....
FC-8.94
TC-9.67
CC-.73
PH-7.5
CH-168
TA-81
CYA-75
Since they show some CC wouldn't that be more accurate since I have algae?
