Thus the problem with pH meters.
They may be accurate immediately after you calibrate it. After that who knows.
One more lesson learned! Calibration may not hold that long so it’s a good idea to check it with a standard solution first.
Glad I don’t have cataracts, yet. At least according to my last eye exam. I have horrible eyesight so I see the eye doc every year. Despite that, I still don’t see some colors that well.
You're proving my point about using a meter over the drop tests.
I’m doing a good job of that, aren’t I?
On to another topic.
I tested salt this morning and got 3,000. Glad I took my time bringing it up. For anyone curious, the SWG still had the red low salt light on and it registered 2,650 (and still does). I’ve read enough on TFP to know not to use SWG measured salt level for anything and to go by your own testing. This just confirms it, again.
The cell registered good flow all the way down to 400 rpm’s (which still gave me 16gpm). I’ve been running the pump 24x7 at 1,000 rpm’s so that will be plenty. I may even drop it a little. Just to see if the SWG would generate chlorine I set it to 20% and it went to work!
SWG lights:
- Salt level low - red light on
- Status
- cold water light off
- cell green light on while generating for 53 seconds and off the rest of the five minute period
- flow green light on
- Sanitizer output - solid green light on showing 20%
I seem to be losing about 1-1.5 FC daily, but I haven’t been testing at regular times so it’s an educated guess. When I tested CYA yesterday it was 70 so based on my CYA of 70 the FC min is 3 and the target is 5-10. At 8am this morning I had FC at 8, so it seems like I’m starting from a good place as I tune the SWG. After playing around with the effects of adding functionality in PM it showed with the SWG set at 11% and the pump running 24x7 it would add about 1.2 daily (in the middle of my daily loss). I’ll start testing FC around the same time each evening for a little while as I dial it in. If I don’t maintain FC at 8 at the same time tomorrow I’ll goose it with a little liquid chlorine (thanks for the tip
@Dirk) to get back to 8 and bump up the SWG percent whatever is needed to make up the delta.
I’m so looking forward to having this baby stabilized and officially join the TFP club!
I did a test this evening and FC was still at 8 and pH actually held steady. Feeling good!
Oh, despite the water being about 65 degrees, I had a little fun today with our golden retriever learning to swim. I started her on the ledge about a week ago, she now loves that. So today I went in, slowly, and once I acclimated I carried her from the ledge across the pool and helped her float as she paddled her way across the pool. We did that about 3 or 4 times and by the last time I gave her a gentle nudge forward and she swam the rest. I may regret it, but it’s gonna be heating up soon in Phoenix and I wanted to give her a way to cool off. She didn’t seem so happy last summer.
