Hi Everyone,
We have had our new inground plaster pool (wetedge) for about 4 weeks. It is an outdoor chlorine pool. We hired a pool company to get us started with maintain our pool chemicals as we have had a busy summer and didn't want to start off getting algae. Unfortunately we haven't had great luck. We have roughly a 20x40 pool (~ 29,000 gallons). I really hadn't had much time to research about chemical products but because we haven't been happy with the pool service thus far, I decided I might need to get a better understanding of everything to ensure our pools health. My parents have a pool and live in the same area came to help us test as after the first week of it being filled because it seemed very cloudy. The pool service was started at that time, and when my dad tested we had a 0 chlorine level at that time. We threw in a floating chlorinator with 4 pucks and called the pool guy to come back out the following week (as all this happened over the weekend). They came out and for the next few days things seemed better and the pool was clear. Because our plaster was new we were doing all the brushing and we are also surrounded by a lot of dirt right now from our pool dig - so I understand that some cloudiness might be a bit normal at this point. However, 10 days ago I noticed a yellow spot on our pool baja step and I couldn't brush it off, even with lots of elbow grease. There was only this one spot and we were headed out of town and the pool guy was set to come. I figured they would handle the spotting with chemicals. We came back from being out of town for 5 days and now we have several noticeable yellow spots both in the shallow and the deep end that we cannot brush up. Unfortunately we returned home over the weekend again, but I was so frustrated I took my pool water to get tested on Sunday at Leslies which showed the following.
free chlorine - 0
total chlorine - 0
ph 8.5
total alkalinity 160
calcium hardness 140
CYA - 0
*Based on my first weekend of researching here on the forum it seems as though our biggest problem is no chlorine and no CYA. At this point the pool guy is supposed to come Monday (today). I am hoping to meet him and ask some questions but based on the process so far I am starting to think we may have better results doing this ourselves. As we live in a very hot area (summer is usually 95-108 daily), so I think we will need to be adding more chlorine daily. A few things I don't understand are what products are best used. *We still have some pucks floating and I did notice they put one puck in each of our skimmers. But overall this doesn't seem to be nearly enough chlorine.
Based on what I read it seems as though liquid CYA is the easiest. Is there a brand/maker that is better. Do I add this (and at least get to 30 before adding chlorine?). How long will it take the pool to increase CYA levels? Because we live in a hot area and our pool gets direct sun all day - I am thinking a target of CYA closer to 45 or 50 would be best to reduce the dissipation of chlorine.
Also is there a benefit to the type of chlorine we should be adding daily. My parents say they use about 6 pucks and replenish as needed, and that if there is a hot streak or they leave down they use powdered chlorine (cal hypo). I know calcium hypo can increase calcium over time, and dichlor/ granulated shock can increase CYA over time so it seems like it is just preference depending on the chemistry of your pool. I am looking for simple, draining our pool will never be an issue because of our set up, so I am not too worried about increasing CYA over time. Can I just buy shock and use a scoop of it a day versus buying shock and powder and pucks? Or is the powder chlorine a better option for daily FC addition (in addition to having a few pucks floating). I also did buy a lot of liquid chlorine as I was at the store and thought we might need to SLAM our pool. Does liquid chlorine dissolve faster than the powder, or granulated? I guess I am just not sure if there is a benefit in terms of which chlorine to use? When I went to leslies to get the water tested, they advised 1-4 chlorine tabs at all times, and then adding 2 lbs of leslies shock weekly?
When I am trying to raise the chlorine should I add it at night? Based on the forum it sounds like you add liquid chlorine slowly in the deep end and wait 10 minutes and then can add muriaric acid.... I read some people suggest adding chemicals in the skimmers - then I read that can cause discoloration....
Based on what I have read - which again may not be right, I really need CYA, FC and murianic acid.
Sorry I know this is a bit scattered I just need some advice on where to start, and if liquid, versus powder versus granular has pros/cons in terms in regards to how quickly it dissipates in the pool (I understand the pro's and cons in that some elevated CH, and CYA). Thanks so much for any and all recommendations.
free chlorine - 0
total chlorine - 0
ph 8.5
CYA - 0
