Our new pool install is almost complete. Some of their recommendations we have received during this build is in conflict from information on this site. So I would like to verify.
The builder originally recommended a mesh cover. I am sure their standard cover is entry level, they never mentioned there were different grades/quality mesh covers. I am not even sure what brand cover they install. I assumed Lathem, but some other equipment has been no name, ie Hayward/Pentair clones........
I would like the Lathem 9000 Mesh
The main reason we decided to go with a mesh vs solid cover is that the builder stated it is a safety cover, we could have it installed when we closed the pool and remove it when we open. Nothing else would be required. The mesh cover would allow rain to flow thru, it would hold the weight of any snow we get and when the snow melts, like rain it would simply drain thru the mesh into the pool. It is designed to allow water to drain into the pool, any excess would simply run over the pool on the deck, then run off the deck. When I asked about the sump tube filling up, they said the only maintenance that may be required is to check the sump, but they also said they have never seen an issue when the pool was full. The only purpose of the sump tube is to remove water if the pool needs to be drained.
A solid cover would require a pump, there may be some low spots in the cover and require the pump to be moved, as well as make sure the pump does not freeze.
I plan to follow TFP closing recommendations.
