Greetings all !!!
New to the site, found you through the all mighty interwebz.
I recently moved to Colorado from Michigan and have come to the realization that Coloradans don't fancy the pool as much as Michiganders do even though Colorado gets more "pool time" during the year than Michigan does. I am a DIY kind of guy and therefore it has been tough trying to learn about how I can accomplish what it is I have in my head because every pool place I have called in Colorado does not do above ground pools, they all only do full in ground $100K+ pools. I can't even find a place that will sell me an above ground pool so it's looking like I'm just going to have to buy it online.
Having said that I'll try to explain to you my vision and paint you a picture.
My house faces south. I have an area of 30' from the back of my house to the start of a 3' easement before the back fence. My house is ~40' wide. It is 62' from the east side of my house to the west fence (22' from house to fence line). I am considering an oval pool, 52" or 54" (don't care) and either a 15' or 18' x 30' or 33' positioned about 5' from the west fence line extending about 15' behind the house. My house is a 2 story house and blocks the sun directly behind the house all day long. This is why I do not want to put the pool directly center behind my house and want to move it to the west as much as I can so that 1/2 of the pool will be in the sun all day long and the other 1/2 will gradually get more and more sun as the day gets later. I'm considering salt filtration as well and a deck on the east side of the pool. The filtration system will be on the North East side of the pool hidden underneath the deck. My backyard is on a slope so more of the pool will be in ground closer to the house than towards the north fence which will allow me to conveniently hide the pools filtration system underneath the deck. I have not done any vertical calculations on the slope/height of the pool or how much I will need to excavate as this is just an initial idea I'm looking for more feedback on from you pool guru's who know this inside and out vs my family who is just like "when can I go swimming already?". If this seams to be more of a solid idea then I will get more accurate vertical dimensions. I have attached a picture of my initial idea.
So my initial questions for you pool guru's
1) I'm the kind of guy who is always saying "Go big or go home", so do you think the 18x33 like the picture shows is too much for my tiny backyard? When you shop for an oval pool and it says 18' x 33' is that the outer dimensions or do I need to fix my image and make the pool bigger ?
2) Recommendation on brand ? A semi-inground pool I estimate (because I have not done any vertical measuring yet) I will only need to go to 24"-36" into the ground on the south side of the pool. The idea is to build a deck flush to my back door and not have to step down and then the deck be at pool railing level.
3) I have not decided how to tie the deck in with the pool railing yet. I have seen pictures where the deck stops just short of (or just under) the railing but seams like that would be a trip/stub foot hazard and possibly be inviting for people to stand on the railing and damaging it, and I have seen pictures of the deck going over the top of the railing as to protect the pool railing. What are your experiences? Pro's & Con's ?
4) Salt water system, love it? hate it? I know already that I will be the only one taking care of this pool. I've read that the salt water system is more costly at first but less maintenance. My only concern is that salt water taste like the ocean. Is it the same experience? can you smell the salt or chlorine that it produces ?
5) When I excavate, can I make the east side of the pool deeper ? Are there liners that allow for that or no ?
6) I've also toyed around with the idea of positioning the pool at a 45 degree angle instead of completely horizontal like in the picture. This would give me more sun light and deck space, thoughts?
I appreciate any and all feedback.
Thanks !!!
Thanks !!!
