Hello all, found this forum after looking up pool information! I am a novice and would appreciate a review of a quote we received for a builder we're thinking of using and comments on parts/pumps. Waiting on a couple other quotes still.
The pool is small - 88 LF, our backyard we do not have much room left and wanted some turf/play areas for the dogs/kids to run around still outside of side yards.
Questions:
- We may see if we need to add a foot to the sun deck for loungers and potentially move the steps to only half or a corner of the sun deck?
-I do know i will ask for the updated Pentair controls from the older easy touch. Much cost increase?
-I have a heater (we're in southeast texas NE of Houston) - wondering if a chiller/combo unit would cost much more and be worth it for hot 99 deg days.
-Want a darker plaster/pebble and thinking i will have to upgrade to a level2 to get? Pebble sheen worth it for texture? Or worth just adding in glass beads?
-I've read to potentially use halogen light and switch to LED bulb to save some cost? I'm big on "ambiance' thus have the requets for LED lights and sundeck colorvision bubblier lights (QTY 2). Not sure i can do anything on those.
-They have allowance for porcelain tile - would prefer glass but i think the budget would double for that? $12 sq/ft? Worth it for those that have?
-SWGC - i know this is talked about often for Texas PB's here. I will ask - significant cost increase? Equipment needed?
-We're planning on having turf installed in leui of decking - we like the greenspace and have dogs and small children (1&4).
Would love thoughts on the design, usability, cost savings!?
Thanks!
Think
Pool Perimeter‐ Ln Ft 88
Interior Area of Pool‐ Sq Ft 826
Length of Pool‐ Ft 30
Width of Pool‐ Ft 14
Depths of Pool‐ Ft 3.5‐6
New Decking 300
Existing Decking 0
Gas‐ Natural/Propane RIGHT
EXCAVATION
QTY
Base Price 550 Sq Ft. 1
Dirt Walk Over 100' Ft (Measure from Form) 100
Deep End Ramp from 6' and Up 1
Equipment Pad 1
Stakes 4
Extra Skimmer 1
Sun Shelf/Tanning Ledge 1
Raised Beam 12" x ln ft. 32
STEEL/REBAR
Waterfall 3
Ramp Step 1
Masonite Per sheet 35
PLUMBING
Pool/Spa Basic Plumbing w/ 30 ft included & Stub out 1
Pool and or Spa Extra Per ln ft. 100
Gas line 30 ft included (heater, fire pit, etc) 1
Extra gas line per Ln ft. 75
Water feat. connected pool filter pump ea 1
Fill Line w/ auto fill 1
Drain Heads PER unit 2
Connect to Gas meter 1
Gas Regulator(s) PER unit 1
Conduit for each lights 2
Ea water feature Per unit hookup to Pump incl 30' 3
ELECTRICAL
Base Pool 1
Easy Touch installation 1
Sub Panel 1
Sub Feed for Sub Panel up to 60 amp Per ft. 75
Blower 1
Heater 1
Pool Light installation 2
Extra Footage Per ft. 250
360 Bond Loop 1
Breaker (EXTRA BREAKER IS TO PROTECT THE POOL
EQUIPMENT ONLY; NOT INTENDED FOR EXTRA RESIDENTAL
USE) 4
GUNITE
Lifetime Warranty for Original Owner 1
PEBBLE/PLASTER
10 YR Warranty PEBBLETX PLASTER‐ LEVEL 1 COLORS: Mini
white, Salt & Pepper, Aqua cool, Tahoe blue,
Caribbean blue, French gray, Aqua blue, Aqua white,
Sand, Jade, Emerald, Irish Mist 1
TILE AND COPING LABOR
Stone Coping ‐ LABOR/ ln. ft 98
Waterline Tile ‐ LABOR per sqft 50
24" STONE SCUPPERS 3
Raised wall 12" ‐ LABOR/ sqft 36
Stucco back wall finish‐ IF YOU WANT THE BACK WRAPPED
WITH MATERIALS; PLS LET UCP KNOW SO WE CAN QUOTE 1
Skimmers Per unit 2
Waterproofing 1
MATERIALS/MISC SERVICES
16x24"x2" Stone Square Edge Coping per ln.ft 98
Porcelain 12 x 24" $5.00 sqft budget WL 50
Raised wall 12" ‐ Material/ sqft 36
Utility Locating 1
Final Clean Up 1
Material Selections Consult by Mincy 1
Start Up & Pool School/1 FREE MONTH SERVICE 1
EQUIPMENT
Stub Out:
8" Main Drain Sump 2"‐Color: 2
Pentair Skimmer‐Color: 2
Filters:
Pentair Clean & Clear Cartridge 420 Sq. Ft. Filter 1
Pumps:
Pentair Variable Speed Intelliflo Pump 3.95 hp 1
Santation:
Inline Chemical Feeder 1
Heater:
Pentair 400,000 BTU Natural Gas 1
Controls:
EasyTouch 4 No Remote 1
Screen Logic / PHONE APP 1
Lights:
Pentair Globrite 12V; 100 ft w/ Niche 2
MATERIALS/MISC. SERVICES
EQUIPMENT
Page 3 of 6
300W Pool Rated Transformer 1
Auto Fill‐Color: 1
Prowler 920 Robotic Cleaner‐Pentair 1
Blower 2HP‐ Air Supply 1
Check Valve CPVC 2" Straight 2
Resistant Check Valve 1
Valve 2 Port CPVC 2.25' 4
Valve 3 Port CPVC 2.25' 4
Colorvision Bubblier; 100 ft Globrite 2
Umbrella Anchors; COLOR: 2
Brush/Net/Corner Brush/Pole/Vacuum/Hose/Test Kit 1
DECKING
COST VARIES ON SIZE QTY
Dirt, Work & Labor Prep for turf 1
Deck drains ran to pop up. Tie gutters in if available. 125
Turf per Sq Ft 330
TOTAL FOR THIS PROJECT - $$ (doesnt include extra lighting around pool shown in 1 image) or sprinkler/turf repair.
Questions:
Thanks!
Think
New Decking 300
Existing Decking 0
EXCAVATION
QTY
Equipment Pad 1
Stakes 4
Extra Skimmer 1
STEEL/REBAR
Waterfall 3
Ramp Step 1
PLUMBING
ELECTRICAL
Base Pool 1
Sub Panel 1
Blower 1
Heater 1
360 Bond Loop 1
USE) 4
GUNITE
PEBBLE/PLASTER
Skimmers Per unit 2
Waterproofing 1
Utility Locating 1
Final Clean Up 1
EQUIPMENT
Stub Out:
Filters:
Pumps:
Santation:
Heater:
Controls:
Lights:
EQUIPMENT
Page 3 of 6
Auto Fill‐Color: 1
DECKING
Turf per Sq Ft 330
