First time poster/Long time reader of TFP and wanted to share my thoughts given everyone's help/info in the past.
- Why a robot? Was done w pressure-side cleaners. Replaced my Pentair Racer (3rd unit) and booster pump (4th unit in 5 years).
- Why this one? Was deciding between a corded Dolphin and cordless robot. Narrowed it to the Polaris version or this one. The 3-year full-replacement warranty was the easier option. And the price recently dropped as well.
- Why now? The pool has not been cleaned since the booster pump died in January. Sand/silt and larger debris has been accumulating and manually doing it was not working 100%.
I have a ~20x30 kidney shaped pool with rounded floors. Two steps and lounge ledge.
Updated the firmware (ver. 0.40) as soon as it came out of the box and charged it up.
The unit is hefty (23+ lbs) and took about 2 hours to fully charge (came w 60%).
The app was OK but not necessary to run. It does map a (very) rough image of your pool after the first time it does a full pass.
It took 3 hours to do a full wall/floor cleaning. The whole battery was spent and had to fishhook it out. The basket was filled and weighed about 4-5 lbs w debris/sand.
Charged it again and ran it the second day for a 2x pass on the floor only.
Final first impressions:
- The packaging was very nice and they spent good effort to make the unboxing experience nice.
- The access panel to the basket can seem flimsy. Doesn't have a firm 'click' to close.
- It is very solid and built but w the lexan plastic being shiny and new, you know it will get scuffed quick. Wish it was in a dull finish.
- It took two solid charges to fully clean a pool that had not been formally worked on 3 months. I expect regular use will make the job easier for Benny (that's his new nickname)
- The auto-drain for ballasts doesn't work if it runs out of charge. If it's at 0% and you plug into the base to recharge, it will auto-drain at that point. Keep that in mind. My garage got a nice puddle.
- For me, worth it for the $1100 special price. Daily charging will be a new thing but will keep the box for the first 30 days.
Feel free to ask any questions!
