My pool has been losing 1/2 inch water every day. After weeks of troubleshooting, I believe I found where the leak is. Now the water level is below the skimmer, the water loss started to slow down. I believe the leak spot is on the inside of the skimmer face plate (where my arrows point to in picture 1). It should hold about 1/4" of water behind the skimmer face place. I put some water in there and the water disappeared in 15 minutes. The other skimmer holds the 1/4" water just fine. I am not sure about the exact location of the leak. Could be somewhere along the gasket. Or it could be the spot I circled in picture 2. There seems a crack (not very clear in the picutre), maybe caused by one of the face plate screws.
I am wondering if there is a quick temparory fix. If the water leaks through the gasket, can I put something there to seal it up, like caulk, silicone glue, epoxy or some kind of putty? If the leak is cause by that little crack in the plastic, what would you suggest? Any suggestion is appreciated! Thank you in advance.
