The pool heater (Laars Lite 2) uses 2 aluminum tubes to connect to the PVC piping for the rest of the system. One of the black unions started leaking water, but I cannot determine what the appropriate size this would be to purchase a replacement. Can anyone advise? Unfortunately, I am not the original owner, so trying to work through stuff as it comes up.
The pvc piping is 1-1/4" diameter. Below are the dimensions of the nut:
1.9" ID Opening at top to fit 1-1/2" Sch 40 pipe
2-3/8" x 2.26" diameters on the threads to fit a 2" Sch 40 pipe.
Anything at local hardware stores seems come up empty for anything that matches both the thread size and the size of the opening for the part of the piping run. Any help or suggestions are appreciated.
