matthewsunshineflorida
- Sep 28, 2018
- 238
- Plaster
- Pentair Intellichlor IC-40
So this seems to be the best deal I can find on Heliocol 500sqft ($7,600):
www.solarpoolsupply.com
However, the same company makes their own 500sqft design for $5700 which is clearly stolen by heliocol as it has the same mounting system, panel layout, and even 12.5ft dimension:
It looks like a well made panel to my eye based on the stuff I've seen so far.
Then I found the same kit from them on Amazon for $5600 but it also advertises a 15% off coupon which brought the total to $4800. Still not $2.5k, but it's at least a whole lot more reasonable especially given I'd have 500sqft for a 12-13k pool which should give me a lot of juice.
Downside is it's an Amazon coupon which means it could easily go away any day and my pool won't be done for a couple months. But it's $850 off which is hard to resist. If I save $100/mo in gas, my payoff is 4 years plus I'd likely have a longer swim season and I could probably get it to exactly the most comfortable 86-88 temp during the summer and some of the spring/fall. I think I'd do anything under an 8 or so year payout. My roof is 4 years old, so I'm thinking it could at least last until that replacement and maybe longer?
You guys talking about gas heaters failing so quickly makes me feel like I should baby it and use it mostly for the spa and go solar for the pool.
The last thing that makes me nervous is holes in my roof. How do you ensure you hit the joist when you can't use a stud finder through shingles? Also, why do none of these systems appear to have flashing? It seems like we're just going to trust whatever sealant we put in the hole and on top of the screw after putting it in? No other roof protrusions are trusted in this way - that seems really odd to me.
Any other wise words or thoughts on this?
EDIT: Heliocol claims significantly greater performance than SwimJoy, although the difference may not be drastic enough depending on how often we're in the ABCD categories:
Heliocol Premium Solar Pool Heater DIY Kit - World's Best Selling Pool Collector - High-Wind Mounting System
Heliocol systems are known for design excellence with a proven track record for efficiency, reliability, and safety. With a 12-year limited warranty including freeze protection, Heliocol Solar Pool Heating Systems are environmentally safe, low maintenance and roof friendly.
SwimJoy Industrial Grade Solar Pool Heater DIY Kit - Advanced High-Wind Mounting Security - Maximum Freeze Resistance
SwimJoy pool solar panels. Shop The Leading solar swimming pool heater for your home. DIY friendly solar pool heating system for your inground swimming pool or aboveground pool. From the same manufacturer as Heliocol solar panels. Max-Durability, Energy Efficient, Ultra-Secure Mounting for Storm...
Why SwimJoy?
Thanks to the reliability and durability of our state-of-the-art system, you can enjoy your swimming pool for more than just the summer months! Performance & Features Individual tubes enable your roof to “breathe,” which prevents moisture from being trapped under the collector. Tubes...
swimjoysolar.com
