My pool has an in-ground pop-up head cleaning system. The pool is about 11K gallons. The filter is a StaRite System 3. The pump is single speed WhisperFlow and has enough pressure and rate of water flow to operate my OLD Caretaker in-floor cleaning system at 10-12 PSI in the 5-port valve (should optimally be 15-25 psi, but it works fine as it is). With the SWG turned off and the in-floor cleaner turned on I add a 40-lb bag of Arizona's Own pool salt. This salt has a fairly fine grain size. The granules are smaller than kosher salt, about the size regular table salt. Pool temp is about 88 F. After 4 hours I can see tiny sparkling reflections in the water under direct sunlight, possibly tiny salt crystals yet to dissolve. After 6 hours I no longer see any sparking, but there is the faintest 'haze'. I test the salt level using Aqua Chek strips. At the 8-hour mark the haze is gone. I test the salt level again. There is a small difference in reading between the two salt tests. I think this is pretty much consistent and expected. I'm assuming the next 2 tests at the 10 and 12-hour point will reveal the salt level has stabilized. So even though online guides suggest 24-48 hours for dissolution and mixing I'm assuming that the specifics in my case, being very warm water and the effect of the in-floor cleaning system continuously "brushing", that 10-12 hours hits the mark for stable test results.
Is this consistent with other's experiences when adding salt?
Is there any chemical reason to think the salt test results shouldn't be considered stable and accurate at the first point there no visible salt in the water and two consecutive tests 2-hours apart have the same reading?
FYI, the reason I'm doing this this way is that my pool is a strange shape and I want to accurately measure the volume of water in the pool by observing the change in salt ppm with a given quantity of salt. The salt bag was weighed with a precision shipping scale at 40.04 lb and is labeled as 99.8% pure. So in principle, since salt doesn't evaporate, if the water level is maintained I should be able to calculate the water volume from the change in salinity at a given addition of salt.
