- May 3, 2014
- 62,670
- Fiberglass
- Pentair Intellichlor IC-40
You use a hose and wash down into the sand with overflow out of the top of the filter. You must be careful to not damage the laterals. You do not drain or remove the drain plug.After isolating the filter from the pool do I open the drain plug on the filter and allow the water to drain before taking the multi port valve off to start the deep clean?
