Hello,
I'm looking for advices/suggestions to monitor autofill line in order to look for water leaks (if there are any). Based on related posts [1] (very useful), I found:
Are these options today still valid/suggested?
Thanks!
My setup involve an auto fill valve on the balance tank and another manual valve to enable/disable it. This manual valve is near from the pool controller (easy touch) but if cable is required, it must be installed by the wall/ceiling.
[1] Related posts:
- The device Flume 2 Smart Home Water Monitor & Water Leak Detector is a popular option to monitor leaks, however:
- The app report leak for the autofill line and must include an automatic timer valve to enable the autofill in specific times
- The battery could be replaced due to damage (~6 months)
- The electronic valve to control the autofill valve is controlled (preferable) by the pool controller system (Intellicenter or Easy Touch)
- Users include an irrigation sprinkler valve to control the time when the autofill is enable. Some advices to include others protection devices in such configuration
- Nobody include a Flow Digital Display Meter in the autofill line
- Nobody include a Water Meter in the autofill line (similar to the one on the house)
Thanks!
[1] Related posts:
