Measuring cup for chemicals
JimMarshall
0
1,193
Oil City PA
Plastic or glass?
Intuition tells me plastic around the pool but I’m just take back to chemistry class where everything was always glass to prevent reactions.
Can i I use the same cup for bleach and MA assuming it’s well rinsed?
Plastic.
Most have a measuring device for each. When I have to add LC I just pour from the bottle. It does not need to be that accurate.
All of the chemicals come in plastic, so......
I dont see why not, but aren't you usually measuring different ranges of volume? that would suggest different size measuring cups.
of course, jmo.
Plastic only around the pool.
I used the same cup for everything for a couple years until it got brittle and yellow with age from sitting outdoors all year. It shattered when I knocked it off the patio table. Now I just grab a plastic tumbler from the kitchen to gather my sample and eyeball the quantities of acid and bleach.
Plastic.
Honestly, I normally just add LC a jug at a time. :p 1 jug of fresh 12.5 gives me 3 days of LC, I normally don’t test and add daily.
Ive been eyeballing MA too. Last time I significantly overshot though, so I figure I need to make certain I’m a bit more precise with that one
