Hi everyone, I have a Prowler 920, which uses the Maytronics drive motor 5521259-1. It is not working, and I've narrowed it down to the drive motor; it spins freely, gets stuck and becomes very hard to turn. I've seen a helpful video on how to get to the impeller bearings, but how on earth do you get the black plastic ring off the drive motor? As you can see in the picture, what appears to be the bearing is corroded, and you can see rust on the shaft. As you can see, I've tried to spin off what looks like a plastic nut but it won't budge. Does anyone know how to get this black plastic piece off?? TIA
