Main drain line corrosion signs
A Variable Speed pump (VS) should have continuous power and not be connected to a timer. The pump runtime should be controlled by its internal control panel and clock. A separate mechanical timer can control the SWG. Care must then be taken for the SWG timer to turn on 15 minutes after the pump begins running and SWG power off before the pump turns off. This can become a problem when house power is lost, and the pump retains the proper time while the mechanical timer does not.
Thank you for your advice. It's just a bit frustrating for me to have spent so much money on the Intermatic controller and setup, only to now have to revert back to using the pump. I tested the 1500 RPM setting, and it's very quiet. I’ve set it to run for 12 hours, and the skimming works well. The vacuum is a bit slower, but with it running for 12 hours, it should still be enough to catch the debris. I’m also planning to buy a power vacuum, which would allow me to remove the suction vacuum from the pool and possibly lower the RPM even more. What do you think of that plan?
Niiiiice. Was the 1500, 200 over the SWG turning off? When you clean your filter, do the process again and you'll be able to lower it more...maybe.
Run your pump for a reason. Filter, mix chemicals, create chlorine, heat the water, skim etc. If 1500 works for filtering (water look), SWG, vacuum, skim...you are golden.
If the vacuum doesn't get that you want, program an hour at higher speeds to get vacuuming you want. etc. etc.
Your father will be happy (noise) and your pocket book will save about $100 a month.
Speaking of which, TFP is a 503c. We are all volunteers and we keep the lights on with supporters. Please consider becoming a supporter.
Fairly speaking, I’ll test all the settings and keep you updated. You’re right, I just donated the silver supporter option to this amazing resource. I really wish I had found this sooner! Thanks again to you and other forum members for all the time and effort you've put into helping me with my issues. I really appreciate it!
You got it. Thanks for the support. TFP has saved me thousands. No joke.
Now, back to testing. How are you testing your water?
On pool math, use your TFP login and password. Enable sharing with TFP...then we can click on your name and see results. To store results, you need the subscription...it $8 per YEAR to keep a log of tests and chemical additions. Free versions saves only the last results.
The testing is still in progress. I used to have some old test kits, but some are expired and others got lost! 😅 I was going to ask how to test FC—mine is an old 2-color dye test kit. Do you think that’s still accurate enough?
For the salt level, I used to use strips, but today I ordered this one:
Salt Level Test Kit.
I know you might be a little disappointed with all these digital versions, but I’m going to give it a shot and see if it works.
For CYA, I also ordered a refill agent since I’m out of it:
CYA Refill Agent.
Do you think there’s any other test kit I should have?
No. (see below).
Send it back. There is a much more accurate and reliable solution (K-1766 see below). More expensive, but I can't tell you the number of times we have issues with digital testers.
Yes. Get one of the recommended test kits. Link-->Test Kits Compared
We don't care what you get:
TF-100 SALT TF-100 Salt Test Kit
TFPRO SALT TF-Pro Salt
Taylor K-2006C and K-1766 (salt). Amazon.com and Amazon.com
They are all the same Taylor reagents. The benefit of the TF kits (separate company and run by a member) is that there is 2.7x the amount of the FC testing solution, and the speed stir in the PRO makes testing accurate and reliable.
We also have had a lot of reports of bad reagents from Amazon because they sit in a hot warehouse and degrade. TFTESTKITS will stand behind any issues and guarantee reagents for a year.
Having a proper test kit will save you $$ and save you from chasing your tail.
Reactions: proluxline
No. (see below).
I just skimmed a bit, and it looks a bit complicated for me to read each test and understand how to check it. That's why I was thinking of getting an easier solution. I agree with you that the products you suggested are much better than the ones I mentioned. But I need some videos or guides with clear instructions so I can use all the chemical tests. It’s a bit overwhelming for a newbie like me.
Don't be overwhelmed. Do each three times and you will get it. I was the same in the beginning. Take it as a learning experience...new frontiers!
Here are the instructions for each...easy to follow...you can print them out too. Each kit, taylor or TFTESTkits comes with instructions.
We have had 100s of thousands learn. Seriously.
You will be a pro in a week!
Videos if you like!
Videos if you like!
thank you for the links, I will check the soon and let you know.
Reactions: PoolStored
For prosperity, there is easier, then there is accurate. It may be easier, but if the results aren't accurate you will be chasing your tail.
The kits we recommend are more accurate than any other available alternatives; outside a laboratory.
FRAM commercial...pay me now or pay me later. The accurate test kit will save you time and aggravation.
